How to read data from spreadsheet as a look up table
Hello Can anybody please help me out in this..??
I want to read data from a spreadsheet file as it is a look up table.
I want to create a program which lets the user enter an element which is be found in the data in the spreadsheet file and gives back the number which is to the adjoining column of the element in the spreadsheet file.
Example i have the following data in spreadsheet file:
Range  Count
2              10
4              49
6              60
Etc.
If i enter 2 to search the data in the spreadsheet file, i do expect the program replies back with the answer 10 and so on...
Can anyone please help out...
Thanks in advance...
Message 1 of 18
(4,382 Views)
What exactly have you tried so far? Is this a csv file that you can use the Read From Spreadsheet File or native Excel? Either way, after you have read the file, you would have a 2D array and then just a Search 1D Array on column 0. Use the returned value and index array on column 1.
Message 2 of 18
(4,380 Views)
Message 3 of 18
(4,368 Views)
@apok wrote:
Why autoindex the output?  You should only have 1 output.  Besides, the Search 1D Array is simpler (no loop needed).
Message 4 of 18
(4,355 Views)
@crossrulz wrote:
might be 2 cases associated with that # and how does using a for loop make it any less simpler? is this a matter of opinion....wonder what the bench marks are?
Message 5 of 18
(4,348 Views)
Yes i have tried the data to be read using a csv file.
I even tried reading the data using a 1d array and sesrching the index so as i can link it with other part but the reult i found was always a 0 or -1.
Message 6 of 18
(4,325 Views)
apok wrote: might be 2 cases associated with that # and how does using a for loop make it any less simpler?
Both methods are flawed. Tim's solution will not correctly work if no match is found.
The FOR loop version will return an array (possibly empty). Since the requred output is a scalar, it also does not solve the problem.
Message 7 of 18
(4,320 Views)
hello apok
can u just tell me which block have u used??
Message 8 of 18
(4,310 Views)
If your code does not work, then attach the VI/block diagram image and the data file.
The posted examples are either snippets or have all functions labeled. Your request for 'blocks' does not make much sense. And please use full words.
Message 9 of 18
(4,300 Views)
i am attaching the vi as zip file
Message 10 of 18
(4,295 Views)
