How to read data from spreadsheet as a look up table
You are only reading off the first row.  You need to get the entire 2D array.  And then you need to index the Columns.  You are indexing the rows.  There is no need for the WHILE loop at all.
Message 11 of 18
(1,002 Views)
can you please attach the vi so as i get the clear idea..?
Message 12 of 18
(999 Views)
Those comments were based on your VI.
Message 13 of 18
(991 Views)
to be true, i am new to labview, so i dont know much of it.
How do i index columns??
so just asked if you could either attach vi or a snip.
Message 14 of 18
(984 Views)
Are all values guaranteed to be integers? If not, and depending on the situation, I would probably use threshold/interpolate array to return interpolated values if there is no exact match.
Message 15 of 18
(982 Views)
I did post a snippet earlier where I indexed the columns.  When you wire a 2D array to an Index Array, you will see two inputs for the index.  The first one is for the row and the second one is for the column.  Just wire up the second one and you got the column.
The Index Array is also expandable so you can index multiple items at once.  This is how I got the two columns into their own 1D arrays.
Message 16 of 18
(977 Views)
i tried the same, but i coudnt any result.
Message 17 of 18
(962 Views)
Then it is not the same 🙂 please attach your VI.
Message 18 of 18
(953 Views)
