How to read data trace from hp4194a into numeric array??
In case you didn't notice, you posted your question to the LabVIEW board.
You could post to the Instrument Control board but I think your question would be best asked of Agilent if you have trouble with understanding what is in the manual and knowing how the instrument works. You do not have a problem with either NI hardware or NI software. You could also look at the source code of the LabWindows/CVI driver. Even if you don't have that or a C compiler, you could still view the source code with notepad.
Message 11 of 11
(595 Views)
