How to read more than 125 Modbus Holding Registers?
@RavenFan
PBP
Labview 6.1 - 2019
Message 11 of 13
(968 Views)
@RavensFan wrote:
Yes.  That is what I was thinking.
Are you getting the same errors or different errors?
Have you figured out what your original error means?
I am still getting the same error. Even with just one read block I get the same error sometimes. I think it has to do something with the connection but I am not sure.
Message 12 of 13
(958 Views)
Hey RavensFan,
Can you take a look at the modified VI?
I am able to save the data to a text file but the connection on the server side is lost after some time and it just writes '0' after that. I tried to capture that error and reinitialize the connection to the device (as you suggested) but that is isn't working. 
I get these errors:
I don't know why but it stops writing data at 58th minute of every hours. After connecting that case structure handling the error it re-established the connection but after few minutes it again lost the connection and no data was being written to the file.
Message 13 of 13
(927 Views)
