How to read mutiple channels simultaneously in vc++
Previously, I create a task to read 6 channels in vc++. The method I use is reading eatch channel separately. Here, problem rising! One channel take one second, and six is six seconds. It's too long to my control system. So I want to read them simultaneously. One sulotion I know is using multithreading, but I dont think it is the best. I believe there are other sulotions in DAQmx.
Here is the main code i use now:
DAQmxCreateTask("",&DAQtask);
DAQmxCreateAIVoltageChan(DAQtask,"Dev1/ai0:5","",DAQmx_Val_Cfg_Default,-5.0,5.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(DAQtask,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,N);
DAQmxStartTask(DAQtask);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai0");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData1,N,&read1,NULL);
DAQmxStopTask(DAQtask);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai1");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData2,N,&read2,NULL);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai2");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData3,N,&read3,NULL);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai3");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData4,N,&read4,NULL);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai4");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData5,N,&read5,NULL);
DAQmxSetReadChannelsToRead(DAQtask, "Dev1/ai5");
DAQmxReadAnalogF64(DAQtask,-1,10.0,DAQmx_Val_GroupByChannel,OriginData6,N,&read6,NULL);
DAQmxClearTask(DAQtask);
Thank you for your reply!
Message 1 of 9
(3,626 Views)
The board I use is PCI 6221. I'm afread the multithread cannot work...
Message 2 of 9
(3,619 Views)
Since you posted in the LabVIEW forum, please explain how the question is related to LabVIEW. I don't quite see it.
Message 3 of 9
(2,201 Views)
This is almost trivial to do in LabVIEW using DAQmx.  Depending on what you want to do with the data from the six (simultaneously-acquired) Analog channels, you could probably use 3 or 4 DAQmx functions, a While loop, a Stop Control, and maybe a Chart.
Message 4 of 9
(2,189 Views)
The technique is to put all 6 channels in the same task, and use read/write N channels function with that multi-channel task.
Santhosh
Soliton Technologies
Message 5 of 9
(2,182 Views)
you all answered a 9 year old thread… 😄
(I guess this was triggered by a SPAM message, which is already removed by now.)
Message 6 of 9
(2,168 Views)
Actually, they just posted in the version conversion forum, after which I looked at the profile and saw some unread messages, then assumed they were new too. I should have looked more closely.... 😉
Message 7 of 9
(2,157 Views)
Facepalm moment!
Santhosh
Message 8 of 9
(2,127 Views)
It's still in the wrong forum though! 😀
Rolf Kalbermatter  My Blog
Message 9 of 9
(2,110 Views)
