How to read second last and last row of csv file
@Asif138 wrote:
Thanks for your replay
please send me snippit.
asif
Posting by phone, no snippet. It should take less than a minute to modify your earlier code accordingly. Try it!
Message 11 of 19
(1,599 Views)
i get broken wire when connect from buldle to end input.
see attached file.
thanks
asif
Message 12 of 19
(1,589 Views)
Because you did not wire the template to the middle of the bundle node, thus the element names are not defined. Use a regular "bundle" instead of "bundle by name" and things should fall in place.
(You can also right-click the bundle input to the function...create constant..and wire that constant to the top middle of "bundle by name" as in my code.)
Message 13 of 19
(1,572 Views)
still having problem,
i dont know whats problem
asif
Message 14 of 19
(1,556 Views)
The same problem or a new problem?
Message 15 of 19
(1,550 Views)
same problem
create constant is disable at the input of bundle.
Message 16 of 19
(1,544 Views)
i want to do calculation using your last code,
each cell actually counter values of different parameter.
now i want to take difference of last two row as (423512-423197) and save in other excel file.
this should be done with all cell.
any help please
asif
Message 17 of 19
(1,530 Views)
Once you have the last two rows, taking the difference seems trivial. Did you finally solve the other problem? (If this is still giving you difficulties, you should go back to the tutorials and read the help for the various functions).
Personally, I still think you should do all this with plain delimited text files. Dragging excel into all this really complicates this and will also give you a huge performance hit..
Message 18 of 19
(1,504 Views)
i manage it to saving last row using delimited and reading it, minus with current values and saved in other file.
this is how i solved my problem
thanks for your valuable infomation
thanks
asif
Message 19 of 19
(1,486 Views)
