How to read touch coordinate in Windows XP?
I want to develop a LabVIEW application which will read the touch coordinates, in Windows XP.
For example, the display is 1920x1200 and the touch panel is an integrated part of the display. When I move my finger across the screen, I should be able to log the coordinates, eg. if I put my finger on top left corner of the display, LabVIEW vi should log (0, 0), and (1920, 1200) if I touch the lower right corner. And of course it gets a bit complicated when it comes to specifying the sampling time.
How to do this in LabVIEW?
(2,857 Views)
You can try to track mouse?
http://www.krzysztofszewczyk.net
(2,851 Views)
ok but is there a XP function/dll/api which i can call within LV?
(2,837 Views)
Accepted by splee
try this
(2,832 Views)
How about a VI which will detect two-point touch? Mouse device cannot be used in this case.
(2,758 Views)
