How to read value from Fuji F70S PLC using Ethernet
Hi friends
i want to read value from fuji F70S PLC using Ethernet. as i did not find its driver in OPC server. i found option using modbus. but i never use modbus. can any one share any example the communication with labview and fuji f70s PLC.
asif
(3,055 Views)
any help please...
(3,011 Views)
Patience.
It is very possible that no one else has specifically used the PLC you are asking about.
And it is Saturday, pushing for help just 13 hours after your initial post, when most of those hours were night time for most of the people who visit the forums is just not needed.
(3,008 Views)
Hi Asif,
I haven't found any examples specific to the PLC you're using, but there is a lot of general documentation on communicating with PLCs using different implementations of Modbus. Have you checked out these links?
Connect LabVIEW to Any PLC With Modbus
Introduction to Modbus using LabVIEW
Application Development with Modbus
Jordan
Applications Engineering
NI
(2,956 Views)
