How to read voltage of device that has no driver in LabVIEW?
@Great-Britton wrote:
Hey,
I think it would be a lot easier to go with Yamaeda's suggestion and use Call Library Function nodes to call into the device driver DLL and use their functions instead of doing raw VISA commands yourself.
It would probably be easiest to create a library of VIs that wrap the calls you want to make, and then just use those VIs in your code.
Yes it would but she said she's new to the LabVIEW world.  Learning some basic VISA communications is probably a good way to get started.  Plus, depending on how the DLLs are written creating an interface might be tricky (even with a guru like Rolf helping out).
Message 11 of 14
(1,704 Views)
Hey,
No, it is definitely not easier to integrate a DLL into LabVIEW than writing a few strings through VISA Write to an instrument and reading the response with VISA Read. The only reason to use the DLL approach would be if the device uses a non-standard communication interface (USB Raw for instance), the protocol is not documented anywhere and/or you happen to get the well made, fully tested and ready LabVIEW VI library that wraps the DLL. Anything else is a VERY STRONG indication to go with the VISA functions. It keeps everything fully in LabVIEW source code so you can debug and modify it as needed when your requirements change in the future.
Rolf Kalbermatter  My Blog
Message 12 of 14
(1,700 Views)
Hi again,
I did what you said in the previous replies;
-Throw away the BytesAtSerialPort completely, wire a constant of 20 or higher to the number of characters to read on the VISA Read function. DONE
Then go to your front panel and right click on the "string to write" control and select ""\" codes Display" and enter into that control
!001:SYS?\r
or <CR> is stated. DONE
I also entered this values for com port as my device manuel says
115200 baudrate
8 data bits
1 stop bit
No parity
When I start run button at the begining it gives me the right value of the device voltage in the string indicator.However, a moment later it, y VI still gives me timeout error. What should I do?I attached the display of what I mean. Thanks you all for your helps again.
Also I attahced my VI.
Message 13 of 14
(1,662 Views)
Accepted by quanthema
You inconviniently forgot the step about adding a constant 13 to the termination character input on the VISA Configure Serial Port function.
Message 14 of 14
(1,654 Views)
