How to read written string
Well Portmon is really better than the other tool.
I have now the 2 Log FIles For Hyperterminal and for LV.
Looks Like Hyperteminal sends it Bytewise / per byte and LV sends it as String.
Cu
Richard
Message 11 of 14
(858 Views)
I will try to send the Bytes seperate as well in LV but I don´t know how to write the Loop.
Is there a good example for that?
Cu, Rich
Message 12 of 14
(848 Views)
Try this. The function inside the for loop is String Subset.
Message Edited by Dennis Knutson on 05-29-2007 09:36 AM
Message 13 of 14
(845 Views)
THANK YOU ALL FOR YOUR HELP
We did it. 🙂
It works now.. - The Sensor needs 3 seconds between write and read. If I go under 2.5 sec it gives me errors any 5th time maybee.
I attach the final test VI which works perfekt.
So thanks again and have a wonderfull week.
Message 14 of 14
(828 Views)
