How to reconfigure 1/3 octave band data so that cursor can only go to the center band frequencies
Hi
I need to plot the 1/3 octave band data such that the cursor on x axis can only go to the center frequencies and the y cursor remains on the mnaximum value of that band. I need some help in extracting the data from 1/3 Octave analysis waveform and reconfiguring it so that I can plot new bar graph.
Any help would be highly appreciated.
Ankit
(2,946 Views)
Hi Ankit,
I'm not sure I fully understand what you are looking to do, let me know if I have made any wrong assumptions with the following suggestion.
You can turn on the cursor palette by right-clicking the graph and selecting Visible Items>>Cursor Legend.  Then create a cursor by right-clicking the legend.  When you create a cursor, select single plot instead of free.  This will lock the cursor to the x value of each bar and the y value of the corresponding bar.
Hope this helps,
Regard,
Jennifer O.
(2,929 Views)
Jennifer:
Thanks, This was exactly what I needed. Earlier my cusor was moving all over the individual bar . However I wanted it to go only at the center position of the bar.
Thanks once again
Ankit
(2,923 Views)
