Steps to create a VI to read multiple channels
This is the first time I've used LabView.  I want to create a VI to be able to read viltages from multiple channels and output the value of each channel to individual numeric indicators in the VI.  I know how to read a single channel and I've created a task in DAQmax with multiple channels but how would I put that into a VI that will do what I need.
Albert
(2,445 Views)
Assuming you are using the DAQ Assistant and getting one sample per scan, then you just use the Split Signal and wire the outputs to your indicators.
Message Edited by Dennis Knutson on 04-30-2007 09:49 PM
(2,439 Views)
