How to reduce the execution time of the VI while parsing data from the XML file
I used to read the set of parameter data from the XML file and update each data’s in the output format of the array of cluster. While parsing the data VI taking time to parse data from the XML file.
I have made the VI based on the output format which I have required further operation.
Anyone can help me in this.
Note : VIs snapshot attached in the message.
Message 1 of 21
(4,036 Views)
Please attach code and not pictures.
If I understand what you are asking, you want us to improve the speed of the XML parsing. Is that correct?
Using XPath is slow, very slow. When I needed to parse large XML-files, I switched to a string-based xml parser instead. The one I used then was proprietary but I am sure there are others to find. Your parsing seems pretty simple, so creating some string-parsing should be possible.
Certified LabVIEW Architect
Message 2 of 21
(4,020 Views)
 Code is attached for your reference
If I understand what you are asking, you want us to improve the speed of the XML parsing. Is that correct? - Yes, with the same output format
Message 3 of 21
(3,986 Views)
The XML file would be useful. I didn't see it in the zip nor in the zip in the zip.
A replacement solution won't do the exact same thing for every input. It might still work properly for the correct input...
You use XPath for everything. But the cluster is hierarchical, and so is the XML file. Presumably, the XML hierarchy is resembling the cluster hierarchy. So, instead of searching with XPath, get the node matching the cluster, than link each XML child to each cluster element. There'd be no need for XPath, and going over child elements of an XML node will be much, much faster.
Message 4 of 21
(3,945 Views)
Hi Carya,
Some reasons could not able to share the XML file  here.
Is this one you are talkig about ?.
Message 5 of 21
(3,930 Views)
An edited XML file with the relevant cluster data might help.
XML is very versatile. It's hard to advice on the parsing without knowing the structure of the XML, and it's even harder to extract this structure from the code. Still not as hard as extracting it from an image of the code.
Again, hard to tell without a file and the code.
Does it work? Is it faster? That are criteria...
Message 6 of 21
(3,920 Views)
An edited XML file with the relevant cluster data might help:
 XML file attached.
Does it work? Is it faster? That are criteria...:
As we expected it's not working.
Message 7 of 21
(3,883 Views)
Accepted by dhana03
The built-in LabVIEW XML parsing is quite slow.  See here, though the article is from 2013 I tried a while back and I still had a lot of slowdown when I tried using the built-in parser as well.
There's another post here that does speed trials on XML reading, showing that LabVIEW's XML reader slows down exponentially with the size of the file.  If you increase the number of elements in XML from 20 to 210, you'd expect the execution time to go up by a factor of 10 to 11, but in the experiment it goes up by a factor of 76.
Solution is unfortunately to rewrite all your code using a different XML library.
Message 8 of 21
(3,864 Views)
Hi Kyle97330
Kyle97330Solution is unfortunately to rewrite all your code using a different XML library:
Thanks for your suggestion. It would be helpful if any sample code in which I can run my XML file to get the same output format so that I can explore it from that.
Message 9 of 21
(3,756 Views)
Have look here.  Using one of the libraries there, I reduced the parsing time by orders of magnitude.  (~340x faster!)
Bill
CLD
(Mid-Level minion.)
Message 10 of 21
(3,573 Views)
