How to reference an object in a cluster?
I have a cluster that contains some numeric arrays and several Booleans.  I would like to connect a single reference for the entire cluster to a subvi and have the subvi individually controll the Booleans.  How is this done?  I've worked with specfic opbject references but I don't know how work with references within clusters.  I'm under the impression this has something to do with strict property nodes but I'm stalled on its approach.  I'm using Win-XP and LV 2009 SP1.
Dave
(3,363 Views)
In LabVIEW, How Do I Programmatically Change the Properties of Objects in a Cluster?
If you want to wire the values you can always use the bundle function.
Message Edited by muks on 05-19-2010 07:11 PM
(3,358 Views)
Accepted by dj143
Dave
I posted a Nugget on that topic here.
Don't worry about understanding everything in that Nugget. I wrote it to be entertaining at all levels of LV experience so just take what you need and leave the rest for latter.
Ben
(3,354 Views)
Thank you for the info...
(3,291 Views)
