How to refnum to a numeric constant array in a subvi?
I want to use refnum to point to a numeric constant array.
Which type of control should I select, numeric, array or other?
(3,880 Views)
hi tan,
 I think you can use array of constant refnums in the block diagram instead of creating a refnum to an array..
T hanks and regards,
srikrishnaNF
Srikrishna
(3,870 Views)
Thanks,srikrishnaNF,
Please give me some advice how to use array of constant refnums in the block diagram? thanks.
(3,865 Views)
Hi Tan,
   First create a control and right click on it and create a reference(reference will be created on block diagram)...From that reference  try to create a constant...That will be a refnum for your control(or constant)...Now place an array constant with that refnum as an element...
Thanks and regards,
srikrishnaNF
Srikrishna
(3,843 Views)
