Loading Last Value in FPGA at start up
We are using a FPGA for controlling and measuring. In case the FPGA´s power supply is interrupted, we want the last values being loaded automatically as inital values of the paramters at a start up. Can we use the on board memory for that and how can we implement it?
Thank you,
Alex
(2,890 Views)
Hi Alex,
I'm sorry, but there is no non-volatile memory on FPGA side (only RAM).
Because of that it is not possible to get the last values as initial values...
The only way would be to implement this on your host and get the values from there.
Best regards
Dippi
(2,848 Views)
Maybe you could use an external 'permament' memory module such as NI 9802
Marco
(2,841 Views)
