How to remote control labview
Hi!
I am searching for the most effective way to remote control LabView from another workstation.
With remote control I mean to change some sliders to specific values or to turn on / turn off some buttons.
As far as I know there are some problems by using DCOM (and with it OPC, ActiveX which are based on DCOM) for that purpose.
Would you recommend a DCOM-based solution anyhow or might UDP or sth. else be a better solution?
Thank you for your suggestions.
(4,092 Views)
There are many threads on the subject.  Do a search on VI server.
The following may be included in the Development Suite :
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209051
There are examples within the example finder (Help Menu).
Here are some links for your reading pleasure:
https://forums.ni.com/t5/LabVIEW/Remote-Control-Labview-8-6/m-p/922274/highlight/true#M414749
https://forums.ni.com/t5/LabVIEW/LabVIEW-Remote-Monitoring/m-p/808059/highlight/true#M368303
https://forums.ni.com/t5/LabVIEW/Remote-Panels-difficulty/m-p/943343/highlight/true#M423167
(4,082 Views)
