How to remotely control an instrument?
I have an instrument(TDS Oscillscop) hich is connected to a host computer through GPIB, so how can I do to control this instrument at home? thanks,
Mike
(3,078 Views)
There are many ways to do this probably the easiest is to set up your local vi for control to publish to the web.  This is under tools->publish to the web.  Other code based methods are to set up client server architectures like TCP/IP or data sockets.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,066 Views)
In addition to Paul's suggestions, if you have LV on your home computer you can use also use VI server to dynamically call VIs.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,058 Views)
could you please let me know the detail of this method?
Mike...
Message Edited by happybird on 07-25-2007 11:24 PM
(3,052 Views)
You could configure the host computer to use VISA Server, then access the instrument as if it was connected to your computer at home.
The concept is simple, but things like firewalls, routers and port number filtering often get in the way when trying to do this sort of thing over the internet.
http://zone.ni.com/devzone/cda/tut/p/id/4789
(3,032 Views)
Duplicate post.
Please stop posting the same question on multiple boards. You will begin to irritate people.
(3,017 Views)
