Missing XControl
I used an XControl that I renamed, unfortunately you can't select an XControl with a different name in the 'Browse for missing XControl' dialog.
But I replaced all instances.
However when I load my main VI it still wants to find the renamed XControl. I couldn't detect where I am calling this XControl.
So I created an XControl with the original name and couldn't find where it was called.
I broke the facade VI but my Main VI is still working and I can't find where the problem lies.
Can someone point me to the right direction
Ton
My LabVIEW Ideas
(2,554 Views)
Hi Ton,
Do you have an example so I can take a closer look at the problem?
Karsten
(2,530 Views)
