How to remove part of ROI selection (cut of two areas)
Dear forum,
consider the following problem:
I load a picture into LabVIEW as an IMAQ (Vision Module).
Now I select two regions of interest (ROIs A and B), which cover an overlapping regions of the picture.
Is it possible to have a selection that results from the cut of A with B?
(Set theoretically writing: A \ B)
Kind regards,
Jan
(3,550 Views)
Are your ROIs square, circle, or free hand?  Can you post an example?
Think you are asking for "not (A union B)"
http://www.purplemath.com/modules/venndiag2.htm
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,528 Views)
Referring to the quoted website, I am looking for case 4) "A - B" or "A complement B".
To quote the site:
Everything in A  except for anything in its overlap with B.
(3,521 Views)
Can you do a fill (white or black) of area B then just grab A?  That would have all of A with the B portion filled in with a solid color?
Matthew Fitzsimons
(3,515 Views)
Accepted by topic author labjan
A complement B
Matthew Fitzsimons
(3,505 Views)
