NI 9265 to control 4-20 mA Mass flow controlller
Hello all,
Right now I am trying to create a control interface for a test stand using LabVIEW, the PID add-on, a cDAQ-9178, and a 9265 current output module.
I have a main VI that has a loop with a few case and sequence structures based on what mode the interface is. My question is, if I use DAQ Assistant to tell the NI9265 to output a current of say 10 mA, will it continue to do so until I reupdate the channel? My issue is that I want to use PID to control my flow controllers, but I need it all wrapped up in loops and statements so I will only be updating the desired current output every second or so, but I want said current output to be continuous. I don't want to send a "pulse" of 10 mA current, I want it to continue to send 10 mA until I give it a new value to emit.
Sincerely,
Mitchell
(3,451 Views)
Hi bieniekm,
Yes.
loop with a few case and sequence structures … I want to use PID to control my flow controllers, but I need it all wrapped up in loops and statements
Sounds like really bad software design…
(3,432 Views)
When you use a DAQmx Write, the output will remain until you use another DAQmx Write. This is something you can readily test. Are you seeing a different behavior? I would not use the assistant and I would not clear or stop the task until the VI is terminated.
(3,429 Views)
GerdW,
I'm fairly new to LabVIEW, so I'm not sure what good software design would be. But breaking down my code, I've got a while loop that keeps my program continously running, with a case structure inside that differs between an "off" and "on" state, with each of those states having a sequence structure. Would this be bad form? Are you open to critiquing code?
Sincerely,
Mitchell
(3,418 Views)
A sequence structure is never a good design pattern. You should look at using a state machine.
(3,409 Views)
A few links
http://www.ni.com/white-paper/7595/en/
http://www.ni.com/white-paper/3024/en/
If you have questions feel free to ask.  Of course making a new thread might be best if the topic changes from a 4-20mA output device to software design.
(3,396 Views)
