08-13-2014 12:55 PM
Hello all,
Right now I am trying to create a control interface for a test stand using LabVIEW, the PID add-on, a cDAQ-9178, and a 9265 current output module.
I have a main VI that has a loop with a few case and sequence structures based on what mode the interface is. My question is, if I use DAQ Assistant to tell the NI9265 to output a current of say 10 mA, will it continue to do so until I reupdate the channel? My issue is that I want to use PID to control my flow controllers, but I need it all wrapped up in loops and statements so I will only be updating the desired current output every second or so, but I want said current output to be continuous. I don't want to send a "pulse" of 10 mA current, I want it to continue to send 10 mA until I give it a new value to emit.
Sincerely,
Mitchell
08-13-2014 01:57 PM
Hi bieniekm,
Yes.
loop with a few case and sequence structures … I want to use PID to control my flow controllers, but I need it all wrapped up in loops and statements
Sounds like really bad software design…
08-13-2014 01:59 PM
08-13-2014 02:42 PM
GerdW,
I'm fairly new to LabVIEW, so I'm not sure what good software design would be. But breaking down my code, I've got a while loop that keeps my program continously running, with a case structure inside that differs between an "off" and "on" state, with each of those states having a sequence structure. Would this be bad form? Are you open to critiquing code?
Sincerely,
Mitchell
08-13-2014 02:51 PM
08-13-2014
04:11 PM
- last edited on
10-12-2025
07:29 PM
by
Content Cleaner
A few links
http://www.ni.com/white-paper/7595/en/
If you have questions feel free to ask. Of course making a new thread might be best if the topic changes from a 4-20mA output device to software design.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
