How to represent Frequency in Hertz rather than Frequency bin.
In my fft code, when i connect the waveform graph to my FFT, the resulting plot is Magnitude vs Freuqnecy in bins (frequency index). How do I represent this frequency in Hertz instead of the index.
Here is my .vi
Message 1 of 18
(5,118 Views)
Message 2 of 18
(5,117 Views)
the fft vi has quite good help, which explains the frequency resolution of the output. you can use scaling options (offset and multiplier) on your chart to match the frequencies
you can also find the help here: http://zone.ni.com/reference/en-XX/help/371361H-01/lvanls/fft/
__________________
Engage! using LV2015
Message 3 of 18
(5,078 Views)
I need other ideas
Message 4 of 18
(5,072 Views)
Hi gijude,
i already answered that in your other thread here! Read the sentence on manipulating the x axis!
Please stop creating double posts when you try to solve the very same topic!
Message 5 of 18
(5,064 Views)
After locating the offset. What do i set in order to have a label of 0 at the center?
Message 6 of 18
(4,982 Views)
Message 7 of 18
(4,982 Views)
Hi gijude,
when your axis use a range from -x to +x your offset needs to be -x…
Message 8 of 18
(4,980 Views)
Hi sir GerdW,
I already get your point, but I still dont know what to connect in my Offset
Here is the screenshot of my block diagram
Message 9 of 18
(4,910 Views)
The offset should be half of your sampling frequency.
Message 10 of 18
(4,901 Views)
