How to represent Frequency in Hertz rather than Frequency bin.
Setting the offset, does not result to a spectrum with a negative and positive frequency.
 I want a spetrum that is centeret at 0 and showing both positive and negative frequencies.
I dont know what to connect in my offset, to achieve it.
Message 11 of 18
(1,464 Views)
Then what did you get?
Message 12 of 18
(1,462 Views)
It just multiplied the x-axis to a larger number.
Here's the result
Message 13 of 18
(1,449 Views)
Hi gijude,
when you just multplied the x axis values you most probably changed the X-Axis.Range.Multiplier. You need to change the X-Axis.Range.Offset value!
Message 14 of 18
(1,425 Views)
Hi Sir GerdW,
I dont understand. Can you tell me what particular setting do i need to have in my offset. ? Please refer to my screenshot
Message 15 of 18
(1,418 Views)
Hi gijude,
all this has been told to you before:
Message 16 of 18
(1,409 Views)
Here's the result
That looks like you made a positive offset instead of a negative one.
Message 17 of 18
(1,401 Views)
@GerdW wrote:
Hi gijude,
there's also a built in functionality of the fft.vi
https://forums.ni.com/t5/LabVIEW/how-can-i-implement-fftshift-in-LabVIEW/m-p/3077671#M879128
Message 18 of 18
(1,385 Views)
