How to reset everything to default?
Hi there,
  Is there any way to reset all controls to default? I search it here and someone suggest to use the "Reinitialize Values to Default" in the Edit menu, it works for the value field. But to some control like Case Structure, it doesn't work. Any other suggestion (without any programming)? Thanks
Message 1 of 8
(13,749 Views)
A case structure is not a control.
To reset a VI to the way it is stored on the disk, you could try a "menu..file..revert..." (of course if you did not edit anything yet, it might be greyed out).
Message 2 of 8
(13,747 Views)
@dragondriver wrote:
Hi there,
You can also do it programmatically using Default Values:Reinitialize All To Default Method as shown below...!!
And Case Structure is not a Control... its, obviously, a Structure... and every time it will execute based on the value tied to its Case Selector terminal..
in order to execute its default (or any other specific) frame, you need to control the value tied to its Case Selector terminal.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 3 of 8
(13,738 Views)
@moderator1983 wrote:
And Case Structure is not a Control... its, obviously, a Structure... and every time it will execute based on the value tied to its Case Selector terminal.. in order to execute its default (or any other specific) frame, you need to control the value tied to its Case Selector terminal.
I was under the impression that he wants (in edit mode!) to have the visible cases the same as they were when first loaded, even after some manual flipping to other cases during editing.
Message 4 of 8
(13,730 Views)
Hi there,
Thanks a lot. Could you please tell me where to call out the Invoke Node block? I only see one under [Programming]->[Application Control]->[Invoke Node] but there is no such item "Default Values".
Message 5 of 8
(13,728 Views)
Accepted by dragondriver
Place the very same invoke node on the block digram, right click it and select Select Method >> VI Server >> VI >> VI.
After that again right click it and select Select Method >> Defailt Values >> Reinitialize All To Default.
Message 6 of 8
(13,715 Views)
You need to first select the right class:
(EDIT: mod was faster ;))
Message 7 of 8
(13,714 Views)
once in blue moon... Smiley Very Happy
Message 8 of 8
(13,705 Views)
