How to resize the front panel to fit different resolutions
Is this solution still true for Labview 2010? Or does that only work for Labview 8?
Message 11 of 12
(1,627 Views)
Hi robin533,
Not sure which solution you are referencing but the splitter bars and property nodes should still work. Also, here are some links that may prove useful.
1) Maintaining Window Proportions with Screen Resolution
2) Programmatically Read Monitor Resolution
3) Getting Display Resolution
4) Setting Window Appearance and Size
5) Window Size Page (VI Properties Dialog Box)
Bill E. | Applications Engineer | National Instruments
Message 12 of 12
(1,609 Views)
