How to restart a number counter?
So I have this number counter. In it's indicator it counts up by 1 every second. It works fine. But at around 32 I want it to start back at 0. Right now it justs keeps counting up for forever. Any idea how to do this? Every option I've tried to implement has not worked and been way more complex than I think it should be.
(3,666 Views)
mhh am not sure if you are trolling or not
try modulo?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,647 Views)
Hi Orta,
you should alway attach your VI to get comments on improvements or solutions to your question…
When you don't know about a basic modulo math operation you should be able to implement some pseudocode like this:
counter++
IF counter >= limit THEN
  counter:=0
ENDIF
(Compared to modulo operation it's slightly "Rube-Goldberg"ish… 🙂 )
(3,637 Views)
Thanks for the replies. No, I definitely understand the pseudo code. In C++ this is a simple operation. But, I dunno, the syntax of labview is weird for me. Getting used to it though.
(3,632 Views)
thats a minimal example
the function is called "Quotient & Remainder"
(3,625 Views)
Hi Orta,
you should have had the time to go through all those FREE online resources offered by NI for LabVIEW beginners…
Conversion of my pseudocode to LabVIEW G:
(3,615 Views)
