How to rotate front panel components in clockwise and anti-clockwise manner?
I want to rotate the front panel component in anti-clockwise/clockwise manner, for example, if I place a square led on the front panel, how I would I able to rotate this?
(6,032 Views)
As of I know you cannot Rotate the components (Apart from label) in the front panel. You may like this Idea to be considered.
(6,024 Views)
While you can't rotate objects, there might be other ways to accomplish what you want. What is it, in the end, that you want to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,019 Views)
Hey Mike,
Thanks for your reply. Actually I wanted to create a seven segment design on front panel using square LED and for this I want to rotate the component.
Ravi
(6,014 Views)
Accepted by topic author ravi0591
For doing this just resize the led vertically and horizontally and allign the seven segment. You really don't need to rotate the indicator for this.
(6,003 Views)
To implement 7BCD LED Or rotating square LED - follow the easy steps:
1) select Square LED on front panel
2) click on the square LED ( you'll see resize dots on the edges)
3) just use the curser to resize it - you can easily give vertical orientation to it: equivalent to rotating.
4) there us no option of rotation hence implement the above steps
(4,244 Views)
