How to run Labview apps in tablet with android os
How to run Labview application in tablet with android operating system?
Can we use Labview mobile module or we must use google play data dashboard for labVIEW? how to install it in PC?
(6,502 Views)
There is no mobile module for Android so Data Dashboard is one option.
What do you want to install on the pc?
(6,490 Views)
I want to run My old labview app in android tablet of course I use serial port.
(6,405 Views)
Accepted by javadi_ali
If you had looked at data dashboard and some of the other links on Android, you would see that you cannot run a LabVIEW app on Android. Nor can you use a serial port. With Data Dashboard, you have a pc running LabVIEW and it publishes to network shared variables. Data Dashboard on the Android allows you to view those variables.
(6,384 Views)
