How to run labview exe with command line
Sorry
What do you mean  property node to read the adjustments and Edit - Read the arguments?
Message 11 of 15
(2,321 Views)
You must have a property node to read the arguments. Simple as that and shown to you already. This modification must be made in your code.
Message 12 of 15
(2,312 Views)
@Eran1965 wrote:
Sorry
Dennis is probably posting by phone again and got "Autocorrected"  A property node of Class "Application" is needed to read the property "Command Line Arguments".  You will then need a VI server reference to your "String" control to write the value.
Hint: actually look at the exampleSmiley Wink
Spoiler
And, it helps to actually READ the FP comments that contain instructions.
Spoiler
Knock it off Tim!  Trust me, He was laughing his head off.
Message 13 of 15
(2,277 Views)
Jeff·Þ·Bohrer wrote:
Spoiler
Almost rolling on the floor after this comment.
Message 14 of 15
(2,254 Views)
Here's an example of what I like to do when passing in arguments to the EXE.
Message 15 of 15
(2,248 Views)
