How to save X and Y vaue from a Waveform Chart
Thanks for your notes!
Firstly, I have 2 VISA resources because there are 2 comunication with the same device. The first is to send one bit to know what the device has to do depending of it. The second resources is for the data sending from the device to labview.The structure propouse is that if the bit sending (that is controlled by a dial) is other than I commented before,
shows a message for the user. Regarding about the initialize the resource in each iteration, you are right! I will change it.
Thanks for your feedbacks!
Message 11 of 13
(725 Views)
You do not need 2 VISA resource controls to do that. You use one VISA resource control per device, not per command.
Message 12 of 13
(723 Views)
Accepted by topic author mlop
Ok!
So, I have to connect the first resource for both types of comunications, isn't it? I will connect  the from the resource to write comunciation and also to the loop read iteration... ¿Is it what you mean?
Thanks!!!
Message 13 of 13
(721 Views)
