How to save a fixed time interval of dynamic data during continuous acquisition?
Hi, maybe someone has an idea how to solve this:
I'm doing continuous acquisition of dynamic data and when I see something interesting, I'd like to save some of the data (i.e. the last 90 seconds). I guess the first step is writing the data into an array? Can I set up the array in such a way that it always contains just the last N seconds (or last N points, discarding the rest as the measurement goes along) so I can then save that data, for example by pressing a button (possibly without stopping the .vi, or maybe just pausing it. This last step is not crucial)?
Thanks for all the suggestions!
(3,262 Views)
Accepted by Tomaz79
Hi Tomaz79,
you can build it like a black box in an aircraft. You can initialize an array with size of your 90 sec. Write all your data into this array with overwriting the specified index. With Quotient & Remainder you will get the correct index for the next value. If you find your interesting value, you can be sure you will have the last 90 secs.
Mike
(3,259 Views)
Do you use a waveform chart? If your amout of data or updatespeed permits it, here is something you can try. Anyway the function you are looking for is a FIFO. Do search for it here or at NI developer Zone
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,248 Views)
Guys, thanks for the suggestions. I was able to solve my problem with the array!
(3,189 Views)
