How to scanning two-dimensional to three-dimensional.
From my program. How to scan from two dimensions to three dimensions. The change will create a signal is sine signal to generate three-dimensional image.
(2,876 Views)
Can you post a screen shot or vi for lv 8.0? will reshape array solve your problem?
(2,856 Views)
I am using labview 8.5. The problem is I can not create a 3-dimensional scanning. From the attached program is a 2-dimensional display.
If you change or introduce me to please help me.   Thank you
(2,845 Views)
Is this related to your other posts: here, and here? If so, you really should keep the discussion in one place so people know what you're trying to do.
You appear to have posted an example that you acquired from someplace, so I don't know what you're trying to do with it. For 3D you need another axis of data. What is that axis of data?
P.S. It's a really bad idea to use your email as your username on a public forum. You're just opening yourself up to be added to SPAM lists.
(2,833 Views)
