How to search from Array cluser?
Hii
 This is the New VI i have attached
(3,094 Views)
In order to search an array of clusters, you will need to use a loop to look at each cluster separately, and then unbundle each cluster to read the specific values contained in it.  Take at look at this forum on Searching an Array of Clusters to get a little more insight as well as examples that may help.
Lauren
Applications Engineering
(3,038 Views)
