How to send HEX command to NI-Visa write
Hello Experts,
I want to convert an unsigned byte array to string and then sent it to visa write.
But I receive irrelevant result. can anyone help me
thank you
Message 11 of 13
(681 Views)
Is it still wrong if you change the probe display from normal to hex display? Click on the "n" on the left side of the indicator.
Message 12 of 13
(671 Views)
Hi Sina,
again you started a new thread for the very same problem…
The probe window shows a lot more "0" bytes than you asked for in your "0x02 0x11 0xEE 0x03" message: where do those bytes come from???
Can you show the complete array content in the frontpanel? (Keep in mind: we cannot debug/edit/run images of code in LabVIEW!)
Message 13 of 13
(639 Views)
