How to send a string variable to Matlab script in Labview 7.1
I had a program which contains a matlab script. It works in Labview 7.0 I figured out that in the new version labview I need to change the type of input varialbes. e.g. from real -> complex; real vector -> complex vector. But I was still unable to feed a string to the string input I created. The error message is: LabVIEW failed to send variable to the script server. Server:"??? Undefined function or variable "***".
(4,922 Views)
The Matlab Script Node only allows six datatypes and they are all numeric types. To workaround this situation, first use Matlab's 'double' command to covert the string to a numeric array. To then use the string in LabVIEW again, you'll want to use the Byte Array to String.vi to convert back into a LabVIEW string.
I've attached a simple VI to this email. Hope this helps!
(4,922 Views)
Thanks. You answered my question. To add on that, I think users can export a string without any format change. Just add an output and define it as a string variable. It works. However, you are absolutely correct that the matlab script node only accepts numeric inputs now.
I attached the modified example here.
Thank you KileenC
(4,922 Views)
Thanks for noticing that. You're right-on. 🙂
(4,922 Views)
in Labview script data tyypes are numeric you can convert data type numeric like double for string and after  simulation convert ack into string check  code pro zone.
(2,852 Views)
