missing VIs or examples for CANopen driver "NI-Industrial Communications for CANopen"
I'm trying to add CANopen capabilities to a project using the CANopen driver "NI-Industrial Communications for CANopen" and I plan to use the  NI PCI-8531 interface.
https://www.ni.com/en-gb/support/downloads/drivers/download.ni-industrial-communications-for-canopen...
I'm using LabView 2021 and installed the latest driver version (20.0) through the NI Package Manager.
However there aren't any VIs or examples installed, which means I can't use it in a LabView program at all.
Where can I find the VIs for this driver, or is there another library I could use?
Thanks, Clemens
(1,324 Views)
Hi there, have you installed NI XNET driver?
(1,287 Views)
It was a version issue, the driver didn't support LabVIEW 2021 yet. But support was added recently and now it's working fine.
(1,266 Views)
