How to send multiple timed CAN messages to a CAN Bus using the USB 8502
I just got the USB 8502 which uses X-NET and was wondering if anyone knows how to send and read multiple CAN messages from the CAN bus. I looked through the examples that NI gives and tried to play with them to send multiple messages; however, it did not work. I found a lot of information for the old hardware USB 3795 series.
Thank you!
(3,288 Views)
What did not work?
What did you try?
Which vi's did you use?
Have you connected the hardware correct?
(3,249 Views)
