How to send single CAN FD Frame by PCIe-8512?
I am trying to use 8512 to commuication with my device through UDS Protocol by 8512. But the XNET Example provided in labview has some issues.
1.  Example <Basic->CAN Loopback Test.vi> run with error  ( Hex: 0xBFF6300A  The Operation timed out.)
2.  Example <Intro to Sessions->Frame Sessions->CAN Frame Output Stream.vi> only calls the write method once (By set the stop button default True) when sending CAN signals, but receives hundreds of the same signals at a 0.3ms period on the bus. Multiple attempts to update the signal value using the write method are also unsuccessful.
How can i use labview to control 8512 to send single CAN Frame?  Or there is some other way to achieve UDS Protocol?
(1,288 Views)
Did you modify the shipping example or just run it as it is?
Did you select any cluster or use the default :memory: database?
https://tmesystems.net/
(1,251 Views)
1. I just run the example.
2. i tried :memory and :can_fd: , but the result is same .
(1,230 Views)
(1,228 Views)
Accepted by sunnywater
Sry! XD
I get wrong wire connect with DB9. Now it works correctly.
Tks a lot for your answer. @ZYong
(1,219 Views)
