How to set LAST used values as default
To run my application,I usually want to set the most of the parameter values same as used in last experiment. I do not want to set the default values manually as I had to use three codes and there would be 20+ controls in all these.
I have included one such code.
(Sorry Evan, I tried to use your code. But it was not very helpful)
Dushyant
(2,460 Views)
See reply here.
(2,452 Views)
