passing data to excel sheet
In my project,iam getting temperature data from a device.There is upper limit and lower limit ,If the temperature reading which iam getting is above upperlimit or below lower limit,then in the excel it should show ALARAM_SET.If the temperature reading is with in the range then in the excel it should show ALARM_CLEAR,along with date and time.Pls provide me an example VI.Iam starter in labview programming.
(2,567 Views)
hofer,
I suggest that you open an example called "Write to Text File.vi" and modify it to do what you are after. You can find the example by choosing Help >> Find Examples, then browsing to Fundamentals >> File Input and Output.
I did a quick modification and am attaching a screenshot; that way (and since I don't know what LabVIEW version you use), you can compare the shipping example with my modification, see how I solved it, and learn by doing the modifications yourself.
John
(2,551 Views)
