How to set analog output for Adam daq 2024 over modbus register valves
(1,255 Views)
Hi Krishna,
@Krishna0012 wrote:
You forgot to write your message text!
Keep in mind: use the title to provide a short, but still good description of the problem. Use the message text to give all details on your problem…
Use any of those Modbus libraries to send a Modbus command to your device. Use the registers and scalings as provided by the manual of your device!
What have you tried and where are you stuck?
(1,251 Views)
Accepted by topic author Krishna0012
Here's a quick Modbus overview that even has some LabVIEW examples
In general you need to study the manual for your device very carefully as without information like a "register map" and scaling factors you are screwed. Only the manufacturer of the device can give you this information.
=== Engineer Ambiguously ===
(1,219 Views)
