How to set date/time on TPC touch panel
How do you programaticlly set the date and time on a TPC touch panel?  How about setting the local time zone?
(2,614 Views)
Hi dbtestcon,
Unlike LabVIEW VIs for Windows, there are no VIs that will allow you to programatically set the date and time on a touch panel. This leaves only one other avenue. You could use the call library function node to refrence a single function in the Windows CE DLLs that will change the time. I dont know what function that would be, so you will need to do some other research, but this is at least one avenue to try.
And on that note, you may concider placing a suggestion in our Product Suggestion Center to add VIs that will programmatically change time.
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(2,590 Views)
