How to set name of X and Y in Graph?
what is the property name to set the name of the x and y at the border of a graph?
The good souding property XScale.Name.Label.text is not working (or is doing something different 🙂
best regards
TM
(2,365 Views)
For me the "X Scale.Name Label.Text" works as expected: it changes the scale label…
(2,348 Views)
Perhaps you should share some code and/or give a better explanation of what you were expecting. My suspicion is that the Xscale.Name Label.text is working properly but your code is not giving it the value that you think it is giving - but I'm only guessing since I have not seen the code.
(2,339 Views)
Attached a screenshot with marked text that i want to change.
(2,331 Views)
Accepted by topic author OnlyOne
If you want to change the Y axis label then you should change Yscale, not Xscale.
(2,313 Views)
head->table
(2,310 Views)
Hi One,
@OnlyOne wrote:
head->table
Lesson learned: always provide code right from the beginning!
(2,267 Views)
