How to set the checkbox state with a button click
Hello all,
O am new in LabView. I have a situation now that I have several checkboxes, which I want to check them all (or de-check all) with a button click. Can anybody help this out?
Thank you very much. Jacie
(3,080 Views)
Hello Jacie,
I have a attached a small VI which I have created to do as you have asked. IT is done quite easily with the use of Local Variables. I hope that you find this useful and do not hesitate to contact me if you require more help.
Regards
David B
Applications Engineer
National Instruments UK
(3,075 Views)
Hi David,
I can not open the vi file, it is 11.0 version while I am with 10.0 version. It says:
LabVIEW: File version is later than the current LabVIEW version.
An error occured loading VI 'Select all.vi'.
LabVIEW load error code 9: VI version (11.0) is newer than LabVIEW version (10.0).
Is it possible you sent me a 10.0 version file?
Thank you very much for your prompt help.
Jacie
(3,069 Views)
Accepted by jacie
If you have multiple checkboxes you will have a cleaner diagram if you group them in a cluster.
Ben64
(3,057 Views)
Hello Jacie,
Sorry for that, here is a copy that is saved in LabVIEW 2010. Is this helpful?
Regards
David B
(3,054 Views)
Thank you, David. Thank you, Ben.
Both solutions work for me. I really appreciate your help. Jacie
(3,038 Views)
