How to set the sampling interval using DAQ device?
Accepted by topic author wzz525
In that case: following the table if you set 5k as rate, the buffer size should be 10kS, however since the samples per channel is a bigger value than the rate, the buffer size is 20kS.
Regards
Message 11 of 11
(599 Views)
