How to setting channel (DAQ) PCI 6024E using with LabVIEW 7
Now I have connected PCI 6024E + installed driver and installed LabVIEW 7 but I don't know
How to setting channel (DAQ) PCI 6024E using with LabVIEW 7. For example I want to use AO1 (Analog Output channel 1) to generate
the signals but I don't know how to send the signals out from AO1 of PCI 6024E.
Message 1 of 13
(3,571 Views)
First , read the user manual of PCI 6024 and get an understanding of your DAQ card's capabilities, its Device pinouts for location of AI and AO channels on the terminal block
The best way to start would be choosing a suitable program from labview examples.
For traditional daq examples, Go to LabView Example Finder : Hardware Input and Output >> traditional daq>> Analog output folder,  and choose a relevant VI,
For daqmx examples, Go to LabView Example Finder : Hardware Input and Output >>DAQmx>> analog generation>> voltage folder,  and choose a relevant VI
Read its documentation and use it for generating signals.
Any doubts, do get back
Hope this helps
Regards
Dev
Message 2 of 13
(3,554 Views)
I have tried your step. But it cann't run, it has some error about DAQ IN and DAQ out. I think becuase of driver for PCI 6024E that I have installed it don't work with LabVIEW 7 ? Can you help me ?
Message 3 of 13
(3,552 Views)
Which version of NI DAQ do you have?
Message 4 of 13
(3,547 Views)
I have version 6.9.2 NI DAQ Software for windows.
Message 5 of 13
(3,546 Views)
Try uninstalling 6.9.2 and installing a higher DAQ version of NIDAQ7.0 or above.
Message Edited by devchander on 01-25-2006 02:20 AM
Message 6 of 13
(3,543 Views)
How to get the higher version please, give me (url) or file download.
Message 7 of 13
(3,540 Views)
These are the latest DAQ versions for DAQmx and traditional DAQ
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937?opendocument&node=132060_US
Hope this helps
Regards
Dev
Message 8 of 13
(3,532 Views)
Thank you so muck. q^_^p
Message 9 of 13
(3,530 Views)
I have tried to installing the new driver that you recomment me.
But I have one question :
How to set the channel of PCI 6024E. For example I want to generate the signals by using AO1 (Analog Output channel 1) to send out
from AO1 channel of PCI 6024E and recieve some signals to measure by using AI2 (Analog Input channel 2) something like this.
Message 10 of 13
(3,519 Views)
