How to simulate a circuit consist of transistors in labview?
Hi leo,
output 4 bit of serial digital data through 4 DOs
When you output "serial data" on 4 DOs then the data will be "parallel": to output serial data you only need one DO…
LabVIEW comes with a huge library of example VIs, there are also examples explaining the usage of digital IO with DAQmx!
Message 21 of 22
(353 Views)
Hi GerdW,
Thanks for your reply!
I need to output 4 different 4 bit "serial data" through 4 DOs.
So I really need some guidance for that. Can you give me some specific advice?
Thanks!
Best,
Jason
Message 22 of 22
(351 Views)
