How to snap cursor to a particular plot programmatically for waveform graph having multi plots.
I am trying to programmatically select the single-plot cursor to a particular plot, my waveform graph has upto 4 plots.
In the 1.png file, I have shown how to assign cursor to corresponding plot using "snap to" function in front panel, the same operation I want to do in block diagram.
Thank You,
msabah38@gmail.com
(2,506 Views)
Accepted by msabah38
You can do this with a property node:
The top is the simple way to do it.
The middle and bottom solutions make it possible to do cursor configuration in a sub VI, by passing the reference... That would allow you to keep your main VI tidy.
(2,488 Views)
Thanks for solution.
(2,474 Views)
