How to snap/grab with a smart camera 1742 (No interface found)
I have a smart camera (NI 1742) and I'd like to snap or grab an image. I saw that there are 2 examples so I ran them, but I always get an error "No interface found". In MAX, I can see the interface (img0) (see picture above) and I can grab and snap images, change parameters of the camera, etc. When I ran one of the example, MAX is close and the error appears in the "IMAQ init.vi".
Since I'm a beginner in Vision systems, I tried to do it myself first (I didn't know there were examples). So I used "IMAQ init.vi", then the error (no interface found) appears.... I used "IMAQdx open camera.vi", then the error (camera not found) appears... I used the "IMAQ1394 init.vi", then the error (camera not found) appears... (see "snap smartcam.vi", but the problem now is that even the examples gave me this error). I know I need to use IMAQ init.vi but since it's not working I tried other things.
I can ping the camera and it works in MAX... I don't know what I do wrong here...
Any ideas?
Thank you very much
Stephanie
(4,023 Views)
You cannot simultaneously use max and init.Close max while you are running ur vi.Have you specified img0 in init.Check it.R u closing each session properly?
I am using lv 8.0.Can you post your vi for 8?
(4,007 Views)
I found how to solve my problem. I needed to create a real-time application with the example.
Thank you for your help,
Stephanie
(3,996 Views)
Hi Peachy, could you tell me how did you solve your problem step by step, please? I have the same problem than you. How did you create the real-time application with the example?
Thanks for your help.
Cris
Impossible is nothing
(3,480 Views)
Hi Cris,
On my old note, it says that I use this knowledge base: http://digital.ni.com/public.nsf/allkb/7FEE6BCFD264175C8625723E000D928E
Hope this can help you,
Stephanie
(3,429 Views)
Thank you very much Stephanie, I solved my problem. For references: LabView doesn't detects NI Smart Camera Error -1074397145
Just one more question, did you need save images or  a sequence of images or an AVI file? Did you can do it? Thank you.
Bebin
(3,416 Views)
